Bonsoir, j’aurais voulu savoir s’il il y a la possibilité d’avoir une fonction CloseDevice sur une seule carte afin de ne pas fermer les autres k8061 merci pour vos réponses
Now there is a function “CloseDevice” added.
The K8061.DLL is now version 3.0.0.1
Here is a link to download it: box.net/shared/p8hszo58sh
There is also a demo software included to the package to test the new feature of the DLL.
The file MPUSBAPI.DLL must be copied to the same folder with the K8061.DLL.
Best place to copy these two files is the Windows’ folder System32 or SysWOW64.
These files can be copied to your application folder too.
The attached driver version 1.0.0.6 (in subfolder K8061_Driver64) must be installed to use this
version of the K8061.DLL.
Super merci, ca fonctionnel nickel ! support technique du produit hyper rapide comme d’habitude
merci encore
