I try to print abs but after 3 prints the nozzle get clogged i have set the temp ad 230 degrees do I have to print with a lower temp and will it help if i lower the flow it’s now set on 100%
Try printing at 220.
Also set the retraction to 4mm and retraction speed to 110.
This can be done in the Cura settings.
I’m even printing ABS at 210°. Set also the flow at 75-80%.
You must find the right combination on a trial and error basis as it’s dependent from your filament brand and color and on the way your thermistor is positioned in the heater block.
Oké i will try some different settings i’m now printing natural color
