Checking the physical 0.0.0 alignment position
Apologies if I have missed it…but can someone give where the 0.0.0 position should be on the heated bed (eg approx. measurement from each edge). This would assist in the final set up.
As several have found, the microswitch arrangements are not exactly an engineering marvel which can make alignment and adjustment an interesting challenge.
T
It’s 3mm from each edge.
Top of page 3 in the ‘003 CALIBRATING THE PRINTER’ section of the manual.
Thanks for the prompt…
T
