Check balanced or unbalanced audio en see clipping
Hi there,
I’ve found the HPS140 and saw a demo on Youtube, very impressive.
I’m looking for device that can help me out on a project in 3rd world country. I need to see if:
  1. Analogue audio output is balanced/unbalanced 0,3Volt vs 1,2 Volt
  2. To see if the audio is clipping (too loud), so a little record function of 1 sec or so.
Could this device help me out on this one, or do I need something else?
add1) I know I can check the manual on a device to check this. But I like to have a reference.
add2) I can check it with a headset, but if you can show it visual to me and the customer… it’s more powerful.
Thanks in advance,
Albert
No problem to show clipping, however, how would determine if a signal is balanced or not, with a single channel scope?
Hi Vel147,
Thanks for your answer.
I’m not too much into audio, more into ICT. What I see here in Suriname that they don’t have too much knowing about what they are doing in the lokal TV industry. And I saw they connected balanced straight to unbalanced input with a TRS connector on a Panasonic audio mixer. What I want is to see on a monitor/oscilloscope what the exact levels are as balanced = +4dbU and unbalanced -10dBV And to show them if they are doing things right or wrong and can support them with graphs.
A better option would be the: PCSU1000, but that is 3x times the price of the HPS140.
Yours sincerely,
Albert
It is no problem to see voltage level differences.
You might want to look at the PCSGU250.
Link below
http://www.velleman.eu/products/view/?id=377622
Thanks for the info.
