Charger K7302 - question
I have a problem / question about the charger K7302.
I bought one, and charge with it a NiMH battery with 8 cells (350mAh)
I charge it with 15,4V input Voltage and 200mA
If the battery is full, the LED turn off. But after that the battery go warm / hot until I remove the battery from charger.
Is it normal? Can it damage the battery?
Thanks for Information.
This is normal the kit is actually a current limiter.
So it will keep charging the battery. It’s not intelligent.
