Channel 2 noise when changing sensitivity PCU1000
PCSU 1000 scope.
When I change the sensitivity from the “5” column to the “2” column, I get a significant amount of noise regardless the coupling selection or the presence of a signal on channel 2.
If I then select a sensitivity from the “1” column and move back to the “2” column, the noise disappears.
I know the solution is to not go directly to the “2” column from the “5” column, but I am interested to know what is happening. Is it a noisy relay? Can I replace it? Which one is bad and where do I get new one?
David
What you describe sounds very similar to what I see on my own PCSU1000. Actually it is not noise, it is an oscillation. Same for me - going to some other sensitivity setting and then moving back to the original one can make it disappear. So you can manually work around it, but it does not help e.g. when doing an automated Bode plot with the PCGU signal generator.
I’m glad somebody else (you) observed that behavior, too - this means that I’m not crazy :slight_smile: It seems to be a problem in the scope’s design (my guess is some stage in the input amplifier does not have enough phase margin and thus becomes unstable). I actually see it more frequently on channel 1 but also on channel 2.
Wolfgang
It is nice to know one is not crazy.
Interesting, so I guess the solution is to be careful how I switch sensitivities.
David
At this time, we are trying to reproduce this behaviour on two of our scopes in the lab, without any results.
Does it show this behaviour every time or just on random occasions ?
Is there any other important info you can supply which could help us investigate the problem ?
Keep us informed.
thank you. It happens every time, never random. It happens after re-booting and a re-install of software/drivers. It only happens on channel 2.
I don’t understand the circut specifics, but it seems like a noisy relay, however, I don’t know why it would only do it when changing from the one sensitivity. I’ve visually inspected the PCB and didn’t see anything that looked bad. Is there a way I can send you a screen grab showing the “smooth” and “noisy” traces? Would that help?
The fact someone else on the list sees the same problem makes me think this isn’t necessarily a random error on my particular scope.
My scope is out of warranty, but would it be possible to swap the circut board for a reasonable fee?
Thank you.
David
Note: In re-reading the original posts, what I have observed and described below may not be the same issue. The oscillations I have observed are transient “settling” events, NOT persistant noise/oscillations.
—my original posting—
Mine does the same thing–on both channels, though with lesser amplitude and less consistency on CH 1. It can be captured easily with triggered sweeps. It does this when switching from “2” to “5” or from “5” to “2”. There is a distinctly characteristic pattern depending on the “direction” of the switch…
This is the CH 2 “2V” to “0.5V” characteristic pattern:
Here’s the CH 2 “0.5V” to “2V” characteristic pattern:
This is the CH 1 “2V” to “0.5V” characteristic pattern:
Here’s the CH 1 “0.5V” to “2V” characteristic pattern:
No, that’s not the same problem. What I see is not a one-time glitch when switching (I wouldn’t be worried about that); instead, I see an ongoing oscillation that does not go away unless I switch vertical sensitivities. I posted that issue when I first observed it - April 2007. (if you want to see the full thread, search for posts with my user name (womai).
Quote:
  • On CH1 when I set the resolution to first to 50mV and then to 20mV/div (or from 0.5V to 0.2V), about one time out of four the signal on the screen oscillates, even though nothing is attached to CH1. Setting a different sensitivity and then setting it back to 20mV/div fixes the problem. I did not observe this when coming from any other resolution (e.g. 10mV/div) either, it’s specific to the 50mV/div -> 20mV/div and 0.5V/div -> 0.2V/div change. The oscillation shows a peak at around 18 MHz (although I can’t tell if it really is a higher frequency that got aliased by the 50 MHz sampling rate). Amplitude is about 0.5units (i.e. 10mV) peak-to-peak. No other vertical setting shows this behavior. CH2 has a similar issue but has much smaller oscillation amplitude. Also there is no influence of the trigger setting (on or off).
Wolfgang
That’s what I thought (that it’s not the same issue) after I had re-read the original posting.
I do not have such an issue on mine. Out of curiousity, of what amplitude is the noise/oscillation?
This isn’t the same problem as I have either.
For me, on the 2 volt/div scale, the noise looks to be about 0.1 volts.
The clean channel has a “noise” level that varies a +/- 1/2 pixel on any scale.
(Can someone explain how to attach an image and I can attach a screen grab)
David
At this time, we are still looking into this issue.
Our lab instruments do not show this behaviour.
More info will be posted as soon asap.
You cannot attach a picture. You can provide a link to a picture, which is hosted by e.g. your provider or a free picture base.
Do you want me to send you my hardware? Happy to di it.
David
Thanks to Cliff, here is the image of the noisy channel 2.
David
FWIW, I have tried and tried without success to duplicate that with my unit…
Yeah, I’m not suprised.
I suspect that it is not a general behavior problem and that it is due to a noisy relay or something. I think it is isolated to just a few units or there would have been a lot of others complaining.
David
Now a modified software is available. I hope it fixes this problem.
You can download the updated files from:
vel255.diinoweb.com/files/PCSU1000_fix.zip
Just extract the files to the \Program Files\Velleman\PC-Lab2000SE folder. (Replace the existing files.)
You may see a minor trace jump when you change the sensitivity from the “5” column to the “2” column.
Thank you! I’ll give it a try tonight and will report back tomorrow.
David
Wow, thank you. This seems to have fixed the problem. Yes, I do see a minor trace jump, but that is not a worry for me.
Can you shed any light regarding what you did to solve this? What was going on?
Thank you again.
David
You folks are amazing! I would also, out of pure curiousity, be interested in what you found.
Nice that this software patch seems to fix the problem.
This is just a very simple workaround: It just avoids direct jump from the column “5” to column “2”. The voltage setting ‘visits’ in column “1” for about 50ms in between.
This patch doesn’t remove the original source of the problem but it prevents it from appearing anyhow…
BTW: In this version of software there is a new “Logic Analyzer” check box added. You may use this new feature to capture a large amount of digital data to the acquisition memory of the scope.
For more info on this function please see the thread: Compress values
Ahhhhh, ok. I wondered if that’s what you did. A band-aid of sorts but it works and I’m happy.
Do you think this “noise” has any effect on the measurements?
I saw the Logic Analyzer check box, but didn’t play with it. I’ll have to give it a try.
So I guess you don’t have any ideas as to why it happens.
Thank you very much.
David
