When i set the temperature at 200 degrees Celsius and slice the stl and then put the SD in the printer, the printer starts at 190 degrees. Earlier printing with my PC i had this issue aswell. What could cause this that i couldn’t set my temperature right before printing. So i don’t always have to adapt the temperature once the printer started printing. Repetier host for K8200 with slic3r. Thanks in advance!
I only bring this up because I have done it.
When you make changes are you saving them?
Are you saving them to the right profile?
Yes, each time i made a change i save it.
I do this for each tab with settings.
And i save it to the correct profile.
Thanks already for your reply
Did you try to change it under the printer settings?
Yes i tried this aswell unfortunately also without success
This is strange.
Have you tried to change it in the Gcode?
I didn’t tried that yet.
But i want to slice my STL, save it to my SD and start te print.
That’s the most easy set up for starting a print.
