Change extruder steps per mm
Hi how do a change the step per mm on the extruder?
I send 100 mm I get 130 mm
Thank for any help
You can do this inside the config.h fil of the marlin setup, but we recommend to leave it on the standard setting. The values are tweaked to accommodate the bowden setup.
Ok thanks
