When the VM201 Remote Control app is started on my PC (Windows 7; 64 bit) it goes by default to 127.0.0.1
This adres is easy to change during that session of the program. However when the program is closed it forgets that IP adres.
How can I change it, so when the program is started is comes with the IP adres that I entered?
Second question:
The VM201 app for Andriod stores the IP adres, but I am thinking about using the VM201 also on an other location.
So I would like to have for example 2 icons on my phone for this app that access differend IP adresses?
[quote]When the VM201 Remote Control app is started on my PC (Windows 7; 64 bit) it goes by default to 127.0.0.1 This adres is easy to change during that session of the program. However when the program is closed it forgets that IP adres. How can I change it, so when the program is started is comes with the IP adres that I entered?[/quote]Currently there is no such feature, I will take a look if we can add this
[quote]The VM201 app for Andriod stores the IP adres, but I am thinking about using the VM201 also on an other location. So I would like to have for example 2 icons on my phone for this app that access differend IP adresses?[/quote]This is not the way an App works, what you are suggesting is technically not possible
