Is it possible to take a CDI ignition coil with the K2543? How many ohms are the minimum for the ignition coil?
Micky
Micky
Sorry, no clue what a ‘CDI’ is…
Max. allowed current for K2543 is 4A.
[quote=“VEL417”]Sorry, no clue what a ‘CDI’ is…
Max. allowed current for K2543 is 4A.[/quote]
CDI: Capacitor Discharger Ignition
I mean not ampere=A. What is the minimum ohm value for the ignition coil that can be used?
Micky
ohms = volts / amperes
In this case: 12V / 4A = 3 ohm
[quote=“VEL417”]ohms = volts / amperes
In this case: 12V / 4A = 3 ohm[/quote]Fine, thanks!
Micky
