Hi
I can’t set the reference voltage on the controller board for the Y motor driver correctly - the pot is very touchy, can only get voltages to set around 0v , 1.5V or 5V - can’t set anywhere near 0.45-0.55V
I suspect the control board is faulty as if I swap X and Y cable connections on the board, Y moves freely but X sticks/jams/hesitates
Any help appreciated
Try to resocket the driver board that doesn’t tune.
If that doesn’t help try swappig it with another axis and try t there.
If both fails, you are likely having a faulty driver.
Hi
Resocket doesn’t help.
Y motor works from another motor socket - e.g. X axis, so wiring is OK.
I believe the board is faulty specifically the Y trimpot - there is an open circuit from the trim pot wiper (ie the Yref voltage) to either of the other terminals of the trimpot - i.e. the wiper on the pot is not contacting and hence can’t set Yref
How do I get a new board?
contact velleman or maybe try here :
http://www.pololu.com/product/1182
