My OS is Windows 7, 32bits.
I download the sorce code of Slic3r from the git, when I compile the code, it pop out the following error:
Can’t locate Moo.pm in @INC at D:/VS2010/slic3rCode/lib/Slic3r.pm line 24.
BEGIN failed–compilation aborted at D:/VS2010/slic3rCode/lib/Slic3r.pm line 24.
Compilation failed in require at D:\VS2010\slic3rCode\slic3r.pl line 14.
BEGIN failed–compilation aborted at D:\VS2010\slic3rCode\slic3r.pl line 14.
Then I want to solve the problem, I download Moo from CPAN and run the Makefile.PL, other error comes out.
Set up gcc environment - 3.4.5 (mingw-vista special r3)
Your toolchain doesn't support configure_requires, so
Dist::CheckConflicts hasn't been installed yet. You should check for
conflicting modules manually using the 'moo-outdated' script that is
installed with this distribution once the installation finishes.
Can’t locate lib/Moo/Conflicts.pm in @INC (@INC contains: C:/Perl/site/lib C:/Pe
rl/lib .) at C:\Moo-1.004002\Makefile.PL line 120.
Dose anybody met the similary problem, how to solve it.
Thanks.
