Hi
i have a little question, when i want to use support material in slic3r, hes printing and some overhanging material, normally he don’t see that after the slicing but now as well. where can i set this to 0/zero so he don’t print the behind the hole in this case
If you uncheck : generate support material
no support is gernerated and printed at all.
But i’m not sure if that is what you wanted.
cheers,
Christian
Okay i understand, for this model, i can uncheck the support material, thats not a problem for this.
but anyway, also i have a other model, hes Always print outside of the model for support, where can i control that?
if he print support materials on the model self thats not a problem but outside of this model, where can i find this setting? for rest he working and printing fine.
thanks for fast replay
Unfortunately wether slic3r nor curaEngine allow you to control WHERE the support is generated.
If that really is a problem for you you can check out simplify 3d. But that is not free software.
Why is it a problem that the support is “outside” the model?
cheers,
Christian
