Can't find Marlin.ino file
I had to make a new installatie after a HD crash. On the previous installation everything was OK
After downloading the Arduino software i can’t find the Marlin.ino file.
I just version 1.0.6 as named in athrer topics.
[quote=“Cokske”]I had to make a new installatie after a HD crash. On the previous installation everything was OK
I just version 1.0.6 as named in athrer topics.[/quote]
Did you download marlin again?
[quote=“ichbinsnur”][quote=“Cokske”]I had to make a new installatie after a HD crash. On the previous installation everything was OK
Did you download marlin again?[/quote]
I made the download as discibede in the manual.
Tryed both the files. In the manualen the say Thatcher te marlijn.ino file in the Arduin folder button I cant find it.
At te first installation everyting went fine.
[quote=“Cokske”][quote=“ichbinsnur”][quote=“Cokske”]I had to make a new installatie after a HD crash. On the previous installation everything was OK
At te first installation everyting went fine.[/quote]
To what directory did you unpack the firmware?
The marlin.ino is in that directory.
If Arduino is installed correctly, just doubleklick that file and it will come up in arduino.
cheers,
Christian
I unziped the file in: C:\program files\Arduino button I cant find te Marlin.ino file in te Arduino folder.
I Am gene try an New istallation tonight, mayby I mist something.
[quote=“Cokske”]I unziped the file in: C:\program files\Arduino button I cant find te Marlin.ino file in te Arduino folder.
I Am gene try an New istallation tonight, mayby I mist something.[/quote]
Look for a folder named marlin or similar in C:\program files\Arduino.
There you should find the marlin.ino then.
Otherwise try to find it by windows search. Mabe you accidetially put it somewhere else.
Anyway, working with projects directly in the programs folder is no good idea on windows.
cheers,
Christian
Started with capter 2 choosing the firmware.
Downloaded the USB driver and connected the printer.
Made a new download from the Arduino site, used the link from the manual
Went tot previous releases to dowmload version 1.0.6 (tryed normal and zip file)
instaled Arduino without result, there is NO Marlin file or folder on my system.
Is there an other site to download the right software?
After reading a other topic I made the conclusion that I also had to download the firmware for the printer.
So after downloading the firmware and past the install steps my printer is working again.
Christian thanks for helping me.
[quote=“Cokske”]
Christian thanks for helping me.[/quote]
I thought you already downloaded the firmware too.
Nice to hear you got it wirking now.
Happy Printing!
