Hi All,
I just wanted to check with the wise and the good on this forum whether I am missing something before I return my replacement control board to my supplier.
I had a fault with my original board that was related to incorrect heated bed temperature readings, so I got a replacement sent out to me.
I fitted the new board and, before switching on the 15v power supply, I connected the USB cable to my Macbook and opened up Repetier. When I click “connect” I get the following 2 lines in the log -
16:01:03: Attempting to connect to printer
16:01:03: Couldn’t open port for device usbserial-A602YW6R
After several restarts of Repetier, unplugs of the cable etc, I tried the original board again and it connects correctly
16:09:02: Attempting to connect to printer
16:09:03: Connection opened
On both boards the green and red LED by the USB socket are lit when the USB cable is plugged in.
I have also tried powering up the new board. In this case the LED’s do not stay lit, but that is the same for both boards.
With the original board, when I connect from Repetier I see the USB LEDs flash with communication. With the new board I see the 2 LEDs flash twice ONLY when the USB cable is connected but nothing after that.
I have tried a reset on the new board which gives 2 flashes of a green LED by the XSTOP socket and one flash of the red USB LED.
I think I have tried all logical steps to prove that the new board has a faulty USB circuit but wanted to double check before I send it back.
Many thanks for any advice.
Peter
