I assembled the mk103 kit, but cannot get it to work. It does not react to anything, except the leds flicker when I connect the battery. I haven’t modified anything, and actually assembled two kits, which both have the same behavior. Is it possible I have something backwards? I’ve checked all the soldering and everything seems fine - how could I troubleshoot the circuit?
If you could post hi-res and sharp pics of your assembly (both component and solderside) we can take a look at your assembly.
Use a free web-based picture base to post pictures.
Soldering is extremely poor. 99% sure this is at the cause of troubles.
Check for loose/forgotten/touching solderings. Make sure there are no solderbridges between two pads that should not touch. Make sure pads have not released due to overheating.
If necessary, have someone else inspect your circuit.
