problems with k8061 dll in windows 7 32 bit & vb2008 compiled vb2005pro example from vista pack 2007 it runs fine in debug but cannot find the dll if published on the same machine published it to a flash drive and stuck that into a vista 32bit laptop it runs fine have tried put the dll in windows file not in system 32 but same result.i just need an example programme that will run with vb2008 and windows 7 32 bit and will publish successfully on the same machine
You can download and try this new software package for the K8061:
velleman.eu/downloads/files/ … k_2011.zip
The package includes new driver and new DLL.
There are example projects written in many programming languages included.
You have to remove the previous driver and install the new driver (v1.0.0.6) from this download package.
Please read the Getting_Started.pdf and the README.TXT.
Copy the files K8061.DLL and MPUSBAPI.DLL from the folder \DLL_3.0.0.1 to the \Windows\System32 folder.
(In 64-bit environment copy the files to \Windows\SysWOW64 folder.)
Thankyou for your prompt reply .The new dll worked a treat first time.
I think it’s important to say that the success of your products is very much owing to the
prompt and helpful support you offer on this fourm again many thanks and keep up the great work.
