Cannot connect (Windows 10)
17:42:34.099 : OpenGL extensions:GL_WIN_swap_hint GL_EXT_bgra GL_EXT_paletted_texture
17:42:34.099 : OpenGL renderer:GDI Generic
17:42:34.099 : Fast VBOs for rendering not supported. Using slower default method.
try connect to my K8200 printer for first time and i get the error message above. It will not connect, im using the standard settings in the user manual of baud 25000, auto detect transfer protocol, 63 cache size. any ideas why it isnt working? I have installed the driver CDM21228_Setup too. It sees the printer is on COM5.
Thanks in advance, regards Jack
I think the problem for no connection with Win10, is because the Setting: “Reset on Connect”
wasn’t set correctly
The correct Printer settings to get connection wit K8200 and a PC running on Windows 10,
see image below:
Regards,
Velleman Support
