Can i run 2 x vertex repetier host?
Can i use the software 2x
Like now i’m printing one object laptop and printer connected by USB.
Can i open another vertex repetier, to prepare a next printjob for an SD card?
Grtz…
[quote=“Ben Dover”]Like now i’m printing one object laptop and printer connected by USB.[/quote]Use only the SD card to print and you’ll have your Repetier ready for your next print job.
The USB connection is far from reliable to print objects. Unless you’re using a correctly shielded cable.
Better way is to use 2 SD cards : one in the printer and the other to prepare your next job(s).
