I’ve put the sticker on a little bit off, there were a lot of bubbles underneath I tried to reposition it but it sticks pretty good. Still bubbles underneath. Can I use the printer without it?
Without a heated bed nothing will stick.
I tried to turn the glass over and print with hairspray.
Sorry to say the did not work either.
I got some bubbles under mine and managed to pull it off, it sits a lot better now.
The best way to apply it is to do a little bit at a time and push that down, that way any air will go out in front of the edge that you are pushing down
I sprayed a solution of water on both surfaces and then applied the sticker to the glaas. You can then easely remove all air bubbles and stick it perfectly flat to the glass.
Example: youtube.com/watch?v=648zplISC7o
That’s a good idea H60.
