Calibrer la K8200 - Calibrate k8200
******** VERSION FRANçAIS **********
Avez vous déjà vérifier les dimensions des pièces imprimées avec votre K8200, elles ne sont pas bonnes. donc comment avez vous calibré votre imprimante, ainsi que la perpendicularité entre X et Y
Merci de vos réponses/conseils
[i][size=85]******** ENGLISH VERSION **********
Have you ever check the dimensions printed with your K8200 parts, they are not good. So how did you calibrated your printer and squareness between X and Y
Thank you for your answers / advice[/size][/i]
Hi maxdgdg,
small holes mostly are printed smaller than designed on my K8200, but the outer dimensions are usually within 0.1 mm (sometimes even down to 0.01 mm) of the CAD model. As for the squareness, you don’t really have any options to mechanically calibrate it in this printer design. You could still edit the interdependency within the firmware - if necessary!?
Cheers,
kuraasu
Je viens d’imprimer une piece qui doit faire 50 mm sur X, 50 sur Y et 10 sur Z
Elle ne fait pas ces dimensions (51.5 sur X, 5.3 sur Y et 10.1 sur Z)
Si a partir de maintenant je change dans scli3r l’echelle, en recalculant l’echelle pour chaque Axe, est ce que cela donnera des dimensions exactes ?
bien sur, je vais tester mais comment faites vouspour avoir des dimensions précises ?
Hi maxdgdg,
attach a ruler to the frame, once in x direction, once in y direction, and add some kind of precise (i.e. sharp or thin) marker to the carriage or heatbed, or vice versa, of course. Use Repetier to move to different positions, back and forth, and measure whether the printer moves exactly as specified. An error of 1.5 mm for 50 mm travel should be clearly visible.
However, a small offset at the home switch is ok if you move the carriage towards the endstop at full travel speed, e.g. moving to 200 and then back to 0 with the arrows, not via “home”. In some cases, the printer then reports the endstop being hit at an offset; this offset should be very small, mostly below 0.1 mm. When using the home function, the carriage should of course always stop at the same position with much better precision …
If this test reveals a false calibration, you should of course change it, but if the values are ok, the error is located somewhere else and the steps per mm calibration should stay as it is.
Cheers,
kuraasu
Mes dimensions sont parfaitement exactes (sauf les trous) 0.1 mm près.
La perpendicularité est correcte également. Comme les distances sont données par le nombre de pas des moteurs, si le diamètre des poulies et le crantage des courroies est bon le résultat est automatiquement correct.
Si l’impression n’est pas de bonne qualité par contre, cela peut changer (plastique trop ou pas assez étalé etc…)
Salut maxdgdg, J’ai un peu le même souci avec mon imprimante. J’ai l’axe y qui se retrouve dilaté. Pour une pièce circulaire de 50mm j’avais bien 50.05 de diamètre en X mais j’avais 51.2 en Y.
As-tu trouvé une solution a ton problème?
Je te remercie
