[quote]after 3 or 4 calibrations the RV1 is bottomed out.[/quote]This is very strange problem.
Normally the RV1 final position is a little counterclockwise from its middle position.
Do you get similar DC mean readings on all the V/Div ranges (5V/div, 2V/div, 1V/div and on 0.5V/div)?
Indeed, the results are good.
The only problem is that there is no more adjustment range left for RV1.
You can fix this problem either by changing R25 (now 20k) to 18k, or soldering 150k…200k resistor in parallel with the R25.
