I just have a quick look at the photo, nothing clearly wrong … hard to tell without a view of the other side … and the curent view angle lets some components hidden …
And also, have you done some voltages measured to compare with the topic i link in my previous post :
Edit 1 : After a more carfull look, it’s look like some resistors confusion … like R8 dont match the documentation ! or im i tired ?
Sorry you have to check all your resistor to find out … if you are color blind your multimeter can help you.
Edit 2 : As R8 is for the LED not a big deal … so maybe just removing and resetting the ICs ?
Tell, if you need more help or if you found the solution.
