Calibration error 59, -201, 200, 200, 200
Hello!!
I mounted my edu09 I connected it to the PC and gives me error in the calibration.
the log file is as follows:
Calibration results:
CH1 offset at 5V/div : 59 FAIL
CH1 offset at 1V/div : -201 FAIL
CH1 Y-position low 200
CH1 Y-position mid 200
CH1 Y-position high 200
What can I do? What do the calibration values?
ps: translated by google translator
Most probably the charge pump is not working.
Please check the -5V is present on pin 7 of IC1.
For more info please see:
viewtopic.php?f=46&t=9325
viewtopic.php?f=46&t=12327
viewtopic.php?f=46&t=12499
viewtopic.php?f=46&t=13537
You can return the EDU09 for inspection/repair to your local Velleman dealer or direct to:
Velleman Projects Tech. Dept.
Legen Heirweg 33
9890 Gavere
Belgium
I measured the voltage on pin 7 of ic1 and read 0.71 volts.
I measured the voltage between the anode of the zener diode and ground (that I took on SK3): -4.80 volts.
The measurement of the pin 7 of the ic1 I have performed with respect to ground.
I live in Trieste, Italy, and it would be problematic to ship in Belgium. What is the problem?
Please do following:
Disconnect the USB cable.
Use ohmmeter to check the connection between the anode of the ZD1 and pin 7 of IC1.
It seems that there is a trace break on your EDU09 board between these points.
Try to locate the break by following the trace step by step.
First step is to check the connection between ZD1 anode and electrolytic capacitor C31.
If OK, then check connection between C31 and IC1.
I measured and the continuity between the zener diode and capacitor C31 was a loose contact. I unsoldered the zener diode and settled on a lead pitch of the cathode of ZD1 and another on the pitch free near C19 which I found to be connected to the negative of the C31. I put the zener diode in a breadbord and I connected to the anode of the thread pitch (the one nearest to C19 and connected to the negative of C13), while the cathode with the other wire to ground.
Result: I measure the pin 7 of IC1 the usual 0.71 volts in my little experience diode is conductive and non-operating zener!
I look forward to an answer, thank you!
[quote=“GabrieleV”] I measured the voltage between the anode of the zener diode and ground (that I took on SK3): -4.80 volts[/quote]If you now solder the ZD1 back to its original place on the boar, do you get -4.8V between its anode and ground?
This indicates that the zener diode is OK.
[quote=“GabrieleV”]I measured the voltage on pin 7 of ic1 and read 0.71 volts.[/quote]There should be same voltage on ZD1 anode and on pin 7 of IC1 compared to ground.
These two points should be connected together.
Check with ohmmeter that all red marked points are connected together.
hi, I tried to see the continuity between the points indicated in the picture but there is no connection. With a lens I saw the track and detached from the pitch! attaching photos of mosssa I had previously done.
I await response
https://drive.google.com/file/d/0Bzq4ymMmlgKjNzB6ZGo1bkZwUG8/view?usp=sharing
https://drive.google.com/file/d/0Bzq4ymMmlgKjTDRmR1VuekZwV1E/view?usp=sharing
https://drive.google.com/file/d/0Bzq4ymMmlgKjdVFJbjRrMVIwamc/view?usp=sharing
https://drive.google.com/file/d/0Bzq4ymMmlgKjSDJQdzBiSHVmR2c/view?usp=sharing
[quote]hi, I tried to see the continuity between the points indicated in the picture but there is no connection.[/quote] You can fix this problem by adding a piece of wire between the points indicated in your picture.
After doing this there should be -4.8V on pin 7 of IC1.
This weekend I’ll try and I’ll let you know
Hello.
okay if the soldering by 5.1 volt zener diode and zener power 0.5 watts or 0.25 watts need to
The original zener diode is:
BZX79C5V1
5.1V, 0.5W
Hello, I have the same problem. Calibration error 59,-201, 201,200,200, however I have checked the connection between the anode of the ZD1 and pin 7 of IC1 and between C31 and IC1 and there is no problem of connectivity.
On the other hand the voltage between anode of ZD1 and ground is -0.7V. What can I do to spot the problem?
Thanks in advance
Carlos
[quote]On the other hand the voltage between anode of ZD1 and ground is -0.7V.[/quote]This may indicate the IC2 is in reverse polarity.
Here is a picture showing how IC2 should be assembled:
It is confusing because there is no notch in IC2 but a dot instead.
Hello. The notch of IC2 is in the right position. Which values of voltage should be achieved? A map with the voltage values in each spot could be usefull.
Carlos
OK.
There may be something strange with the zener diode.
It seems to work as a normal diode instead of zener.
You get -0.7V instead of -5.1V.
You may do a test:
  1. Remove IC1 and IC2 from their sockets (to avoid damage).
  2. Disconnect the cathode of ZD1 from ground.
  3. Now connect the EDU09 to the PC.
  4. Check the voltage on the anode of ZD1.
  • Now the voltage should be about -8V.
In normal operation the zener diode ZD1 limits this voltage to -5.1V.
Here are the voltages of the working charge pump section of the EDU09:
A: 1.56V
B: 0.41V
C: 4.38V
D: 3.25V
E: -2.5V
F: -5V
After step 2 should i have to insert again IC1 and IC2?
Anyway the voltages measured without IC1 and IC2 and ZD1 out of operation (During the operation of taking out the cathode of ZD1 I damage this component) are:
A: 1.65V
B: 0.36V
C: 4.54V
D: 2.62V
E: -5V
F: 0.47V
The voltage E should be -8V with IC1 and IC2 out right?
It seems the diode D4 is defective or not connected.
Please check the points marked with blue are connected together and the points marked with red are also connected together:
If possible, test also the diode D4 with the diode tester of the multimeter.
[quote](During the operation of taking out the cathode of ZD1 I damage this component)[/quote]I’m sorry for the inconvenience.
If the problem is found (maybe around D4) there should be about -8V at F, and also on the anode point of ZD1.
In this case, do not place the IC1 and IC2 back to the sockets before the zener diode ZD1 is replaced.
There should be -5V at point F when everything OK.
Hello.
“It seems the diode D4 is defective or not connected.
Please check the points marked with blue are connected together and the points marked with red are also connected together:”
I have checked the diode D4 and apparently is OK. Checked the points marked with red and also the ones with blue and connectivity OK. However have find out if in the moment I turn on the board (by plugging USB) the voltage in F is very low (if I had discharged C31 before plugging) and stay (measuring F the voltage remains low). If I try to measure the voltage in D4, I find out that the voltage at F jumps to -9V (due to the multimeter???). I have tested with a new multimeter and the same happens, but if only I try to measure D4. If, for instance, I just measure F, nothing happens.
Another information … connectivity between F and blue spots OK. Could be a problem of diode or capacitor?
I have another question. From where I should obtain -8V. Which part of the circuit feeds F spot (where is the source)?
Carlos Geraldes
In this circuit diagram you’ll see how point F is connected.
Diode D4 is feeding the -8V to point F.
To locate the problem please check the following voltages:
  • On the cathode of D3 (should be same as E)
  • On the anode of D3
  • On the cathode of D4
  • On the anode of D4 (should be same as F)
