Cables
We use a Velleman K8047 datalogger to get information from a temperature sensor.
The problem is the distance. The sensor is 300m away from the K8047.
What cable should we use to avoid to many losses?
Thank you.
For such distances you should use a current loop sensor (current loops are not affected by cable losses).
Our K8067 sensor is a current loop sensor.
