Cable for generator in PCSGU250
Please, can you advice me which cable I should use for the generator output of PCSGU250? Can I buy it somewhere? Thanks.
Quite useful may be a
BNC to Crocodile
or
BNC to Alligator Cable
e.g.
velleman.eu/be/en/product/view/?id=340314
Thanks, I guess only 50 ohms of impendance is important, not?
If the cable is short (< 1m) the impedance is not critical. The generator is intended to feed signal to quite high impedance load, 600 ohms or higher.
If very long cable (> 10m) is used then it may be good to use 50 ohms cable and terminate it to 50 ohm resistive load to avoid reflection. In this case the output voltage is half of the displayed value.
