We’re doing a schoolproject with some projectors and the support of the VM116 controller.
we wanted to create our own animation by using C# and the K8062D library.
everything was working fine untill we tried to use a for loop, I’ll explain better:
If we use SetData(channel,data) a single time, then it works great without problems,
if we use a loop or a cycle for, everything stops working correctly, for example:
for (index = 0; index <= 255; index++)
SetData(1,index);
Delay(1.0);
this should loop the function 255 times with 1 second delay and move the projector mirror from left to right, anyway some an unknown reason, the variable “index” after 7 cycles (more or less, depends from i don’t know what) this variable assumes a value around 50000 which is obviously higher than 255 and the cycle stops.
We’re sure it’s a problem related to the library because if we comment out SetData and put a simple message popup telling the index it’s currently on cycle, it works perfectly till 255.
index is an int but i guess that doesn’t matter because if I put it in an infinite loop same thing happens, for example:
int test= 0;
while (1)
SetData(channel,data);
Delay(1.0);
test++;
SetCtrlVal(gui,PANEL_TEST,test); //shows on a panel how many times the while loop repeated
after around 7 cycles the variable test assumes an high value.
I tried using int, long int, double but they all behaved the same.
E: It doesn’t matter what kind of data is written, it’s enough that SetData() is present to make this problem appear.
I’m curious. What might happen if you comment the line SetData(channel,data);.
int test= 0;
while (1)
//SetData(channel,data);
Delay(1.0);
test++;
This seems to work: int index;
SetData(1, index);
Thread.Sleep(1000); //pauses the currently running thread by 1000ms
sorry for the delay,
I was in vacation and didn’t check the forum anymore.
anyway by commenting it out it works just fine,
now i’ll try including system threading.
E: excuse me did you notice i’m using C# and not C++?
because Delay() is a valid function in C# already, without using the system threading namespace and it does the job already.
[quote=“nikooo777”]E: excuse me did you notice i’m using C# and not C++?
because Delay() is a valid function in C# already, without using the system threading namespace and it does the job already.[/quote]
