I have made a wrapper for the K8090Board class and I can connect and turn on/off the relays but I do not get the CommandReceived-message back when querying the relays status.
I am working with Windows 8.1 64 Bit and C#. Does anyone have a hint of what the problem could be?
using System;
using Velleman.Kits;
namespace REL
public class Relay
// Variables
private K8090Board _k8090Board;
private int[] _relayStatuses = {0,0,0,0,0,0,0,0};
private Boolean _jumperSet;
private String _firmwareVersion = "";
private readonly byte[] _relayMasks = {128, 64, 32, 16, 8, 5, 4, 2, 1};
// Constructor
public Relay(String port)
// Connect to K89090
_k8090Board = new K8090Board(port);
_k8090Board.Connect();
System.Threading.Thread.Sleep(1000);
// Register call-back
_k8090Board.CommandReceived += K8090Message;
// Ask for status and meta-data
QueryRelayStatus();
QueryFirmwareVersion();
QueryRelayStatus();
// Query board statuses
private void QueryRelayStatus()
_k8090Board.SendCommand(K8090Command.QueryRelayStatus);
private void QueryFirmwareVersion()
_k8090Board.SendCommand(K8090Command.FirmwareVersion);
private void QueryJumperStatus()
_k8090Board.SendCommand(K8090Command.GetJumperStatus);
private void K8090Message(object sender, Velleman.Kits.CommandEventArgs e)
// Process relay status message
if (e.cmd == Velleman.Kits.K8090Command.RelayStatus)
for (int i = 0; i < 7; i++)
_relayStatuses[i] = e.param1 & _relayMasks[i];
// Process firmware message
if (e.cmd == Velleman.Kits.K8090Command.FirmwareVersion)
_firmwareVersion = e.param1 + "-" + e.param2;
// Process jumper status
_jumperSet = (e.param1 > 0x01);
// Set commands
public void SetRelayOn(int relay)
_k8090Board.SendCommand(K8090Command.SwitchRelayOn, _relayMasks[relay]);
public void SetRelayOff(int relay)
_k8090Board.SendCommand(K8090Command.SwitchRelayOff, _relayMasks[relay]);
public void SetAllRelaysOn()
_k8090Board.SendCommand(K8090Command.SwitchRelayOn, (byte)0xff);
public void SetAllRelaysOff()
_k8090Board.SendCommand(K8090Command.SwitchRelayOff, (byte)0xff );
// Get calls
public Boolean GetRelayStatus(int relay)
return _relayStatuses[relay]==1;
public int[] GetRelayStatuses()
return _relayStatuses;
public Boolean GetJumperSet()
return _jumperSet;
public String GetFirmwareVersion()
return _firmwareVersion;
// System calls
public void SetFactoryDefault()
_k8090Board.SendCommand(K8090Command.ResetFactoryDefaults);
