i bought the Printer 3 days ago and it work great, im happy about it.
But there is one Problem if i try to print larger objects. The dimensions of the print space that is shown at repetier host is not the same like at the printer.
If you provide the repetier host Software from your Homepage with configuration for the K8400 then the printing space should be right configured.
I will try to do this by myself, but there are a lot of options and dimensions to choose…
Maybe you could change this at the next Version of Repetier Host.
thank you
