Buffer block
I have problem, printer does not work. In Repetier line written: Comunication timeout - reset send buffer block
Please anybody knows what is wrong?
FFranci
Check your communication settings :
Baudrate: 250000
ResetOnConnect : disabled
BufferSize: 63
And check if you set the correct com port.
All is correct.
Another idea?
Regards
Franci
One more: I can not choose in Setting name of printer, I have only one option: Defoult
Franci
That is to problem, it’s just a name for the settings file.
Did the printer work before?
No, I just put it together.
Franci
Then check if your 15V power supply is connected and working correctly.
Only USB power won’t work.
I cheched. It is 15V.
Is it problem in PC? PC find a USB port when I connect printer, but in Rapetier I think is not availabile, only default. How can I test if motherboard of printer good?
Franci
What com ports are available in repetier printer setting on the connection tab?
Is serial connection chosen under connector ?
It can help if you post a screenshot of your repetier printer settings.
TNX. I will send you pictures later, now I am working.
Regards
Franci
Hello, here is Picture
shrani.si/f/16/cF/2rx0K71B/print1.jpg
Regards
Franci
The settings are ok.
Can you post a bit more of the error log, especially what happens after connecting the printer?
Try setting the Receive Cache Size to 127
ANET 8A 3D PRINTER
REPETIER-HOST
baudrate 115200
com 6
cache 63
SD REMOVED
TEMP NOZZEL 200/BED 50
This got me going tonight after trying to get my newly built
printer going for nearly 6hrs!
Don’t want to hurt your feelings but this forum board is for Velleman products.
K8200 / K8400 / K8600
