Hello every body.
My 8400 is working very good but on the vertical surfaces there are some rows of small bubbles. Those bubbles are generated when the print head makes a shortcut from one surface to another outside the model during the infill job.
Does someone knows an instruction in Repetier to avoid that the print head don’t leave the outer shell except after ending the print job?
Thanks a lot!
