Brown out reset
During printing my printer gives the brown out reset error. I have checked all power supplies and ensured that there are no shorts. I have checked the voltage going to the board and thay seems fine too. What should I do? Is this a fault with my velleman printer?
I had the same problem while trying to print ABS with high bed temperature.
The main power supply is a little bit low, after that I heard a PLOC and the power supplie was dead.
If you print PLA 60° it’s ok, higher temperature no.
Better have more powerfull PSU or 2 separate, one for the main board, the second for the heat bed and all will be fine
I had a similar problem some months back. In the end I got a power supply from Maplins. It has been working fine since then.
