Broken usb contact
Hi.
After completing the drives test all was working perfect. Then when I start to calibrate the y axis I moved the printer and the short USB Cable stretched and the contact on the CPU board went off… :frowning:
So I toke a 2m new cable and solder the cables directly on the board.
Now when i plug the usb cable in the computer it detects ok.
But it doesn’t work so god. There are commands waiting and the temp shows 0, and no response to any commands.
When I press the reset button it says:
14:32:45.400 : start
14:32:45.400 : echo: Brown out Reset
14:32:45.400 : Marlin 1.0.0
14:32:45.400 : echo: Last Updated: 2013-03-08 | Author: VELLEMAN - GELOEN
14:32:45.400 : echo: Free Memory: 5530 PlannerBufferBytes: 1232
14:32:45.400 : echo:Using Default settings:
14:32:45.402 : N1 M111 S6 *70
14:32:45.404 : N2 M80 *57
14:32:45.406 : N3 M105 *4
14:32:45.408 : N1 M110 *2
Do I need to replace the board or could there bee some other fault ?
By the way i went of really easy, I notice its first when I should plug the cable back. Maybe it wasn’t soldered properly… From now on I will fix the cable in the frame…
