I’m facing an annoying problem, may be two but I think they are linked.
1- The top layer of my part is ugly. There are strings everywhere and mainly, the plastic is pushed by the extruder like if there was too much plastic extruded… Even in some locations, I can see the nozzle trajectory in the plastic
I though that the problem was linked to the parameter in Slicer: “Top infill” in advanced parameters. However, I have tried the range 0.1-0.4 without success. Here is a picture of an example:
And then, on a 2nd example, a little cylinder, the last layers are completely crazy, the plastic is pushed outside the perimeter. Here is a picture:
For that, I have tried to disable “Retract only when crossing perimeter” in Slicer without a change. I tried that because this plastic blob is appearing exactly when the extruder is retracting.
Finally, I think these two problems are related because fundamentally, it’s like extruding too much plastic just on the last layers !
Do you have some ideas to solve that ?
Thank you for your time !
My config:
3d printer: K8200 with homemade extruder + E3D V6 3mm
Plastic: green PLA (really old)
Slicer: Slic3r 1.1.7
Software: Repetier 1.0.6
