Best upgrade you can do :)?
I have connected a raspberry PI to mine with a wifi dongle. I am using the Octo Print software. They do a sdcard image that just works. I also now use Cura for creating my G code files. I have attached my profile with modified G Code start and end codes. It also supports the camera addon for remote monitoring!!
Just copy this code to a file called k8200 and load it in.
[profile]
layer_height = 0.3
wall_thickness = 1.0
retraction_enable = True
solid_layer_thickness = 0.6
fill_density = 20
nozzle_size = 0.5
print_speed = 50
print_temperature = 205
print_temperature2 = 0
print_temperature3 = 0
print_temperature4 = 0
print_bed_temperature = 55
support = None
platform_adhesion = None
support_dual_extrusion = Both
wipe_tower = False
wipe_tower_volume = 15
ooze_shield = False
filament_diameter = 3
filament_diameter2 = 0
filament_diameter3 = 0
filament_diameter4 = 0
filament_flow = 120
retraction_speed = 40.0
retraction_amount = 4.5
retraction_dual_amount = 16.5
retraction_min_travel = 1.5
retraction_combing = True
retraction_minimal_extrusion = 0.02
bottom_thickness = 0.3
object_sink = 0.0
overlap_dual = 0.15
travel_speed = 150.0
bottom_layer_speed = 20
infill_speed = 0.0
cool_min_layer_time = 5
fan_enabled = True
skirt_line_count = 1
skirt_gap = 3.0
skirt_minimal_length = 150.0
fan_full_height = 0.5
fan_speed = 100
fan_speed_max = 100
cool_min_feedrate = 10
cool_head_lift = False
solid_top = True
solid_bottom = True
fill_overlap = 15
support_fill_rate = 15
support_xy_distance = 0.7
support_z_distance = 0.15
spiralize = False
brim_line_count = 20
raft_margin = 5
raft_line_spacing = 1.0
raft_base_thickness = 0.3
raft_base_linewidth = 0.7
raft_interface_thickness = 0.2
raft_interface_linewidth = 0.2
fix_horrible_union_all_type_a = True
fix_horrible_union_all_type_b = False
fix_horrible_use_open_bits = False
fix_horrible_extensive_stitching = False
plugin_config = (lp1
object_center_x = -1
object_center_y = -1
[alterations]
start.gcode = ;Sliced at: {day} {date} {time}
	;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
	;Print time: {print_time}
	;Filament used: {filament_amount}m {filament_weight}g
	;Filament cost: {filament_cost}
	G21        ;metric values
	M107       ;start with the fan off
	M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
	M109 S{print_temperature} ;Uncomment to add your own temperature line
	G28        ;home all axes
	G90        ;absolute positioning
	G28 X0 Y0  ;move X/Y to min endstops
	G28 Z0     ;move Z to min endstops
	;G1 Z15.0 F{travel_speed} ;move the platform down 15mm
	G92 E0                  ;zero the extruded length
	;G1 F200 E3              ;extrude 3mm of feed stock
	G1 E10 F400 ; prime the nozzle
	G92 E0                  ;zero the extruded length again
	G1 F{travel_speed}
	G1 F3900.000 E-5.00000
	G92 E0
	;Put printing message on LCD screen
	;M117 Printing...
end.gcode = ;End GCode
	M104 S0                     ;extruder heater off
	M140 S0                     ;heated bed heater off (if you have it)
	G91                                    ;relative positioning
	G1 E-1 F300                            ;retract the filament a bit before lifting the nozzle, to release some of the pressure
	G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
	G28 X0 Y0                              ;move X/Y to min endstops, so the head is out of the way
	M84                         ;steppers off
start2.gcode = ;Sliced at: {day} {date} {time}
	;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
	;M104 S{print_temperature} ;Uncomment to add your own temperature line
	;M109 T1 S{print_temperature2} ;Uncomment to add your own temperature line
	;M109 T0 S{print_temperature} ;Uncomment to add your own temperature line
	G21        ;metric values
	T1                      ;Switch to the 2nd extruder
	G1 F200 E10             ;extrude 10mm of feed stock
	G1 F200 E-{retraction_dual_amount}
	T0                      ;Switch to the first extruder
	G1 F{travel_speed}
	M117 Printing...
end2.gcode = ;End GCode
	M104 T0 S0                     ;extruder heater off
	M104 T1 S0                     ;extruder heater off
	M84                         ;steppers off
support_start.gcode =
support_end.gcode =
cool_start.gcode =
cool_end.gcode =
replace.csv =
switchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
	G92 E0
	G1 E-36 F5000
	G92 E0
	T{extruder}
	G1 X{new_x} Y{new_y} Z{new_z} F{travel_speed}
	G1 E36 F5000
	G92 E0
For what is this code used?
For cura or octoprint or …?
Sorry, should have stated that. It’s config code for Cura. Octo print is just a G-Code sender with a web interface. Turns the printer into a Wifi enabled 3D printer with support for the camera to monitor the printing.
I use Blender to create the shapes.
Cura to create the G-Code
Octo print to print it out. Would be cool if Octo print could generate the G-Code too. I guess that will come with time. Being based on the Raspberry Pi does mean I could add all sorts of extras. I would go as far as saying velleman should look at crating a version of their main board to plug into the Raspberry Pi and ship the two together with a Octo print preconfigured sd card.
For £50 you can make your printer Wifi enabled. ( Rpi + wifi + sdcard + power )
Here is a picture of it mounted at the back.
