Best power supply for K8067 temperature sensor on K8055
I see that there is a lot a fluctuations when a measure my temperature. K8067 on K8055
Now I use:
PSSMV1 (velleman.be/be/en/product/view/?id=341551)
or i can use :
velbus : VMB3PS with VMBTR1 (velbus.eu/consumers/products/)
or i can use :
K7203 (velleman.be/be/en/product/view/?id=9381)
or i saw that there’s a new range of power supply’s
PSIN02512 : (velleman.be/be/en/product/view/?id=376750)
  1. What should be the best power supply to use?
  2. Is it required that both kits are connected to the same Power supply?
  3. is there a maximum distance between K8067 and K8055. I’ve got max 5meters. Is this perhaps the cause?
Manu
For best results, do not use a switch-mode PSU.
As this is a current loop sensor, distance is not important, if it is within reasonable limits.
K8055 does not require power supply.
