I made a redesign on the belt mounting/tensioning as I was not pleased with the original!
This mod allows tensioning the belt independently and fine tuning the belt mounting on the shaft sledge.
Actually here are two mods that can be used either together or separately.
I made one of both for one axis as other is a âfixed positionâ type and the other allows fine tuning of sledge position.
This type locks the belt from the left side while allowing tensioning with the middle screw and then securing with the rightmost screw.
This type has separate belt tensioner and an adjustable (2mm) belt mounting. This allows fine tuning of the belt/sledge mounting.
Belt adjustment has never been such a joy!
You can have them here: thingiverse.com/thing:691419
