Belt tension 670mm
Hey
I have a big difference in the tension of the 670 mm belts.
The one the front of the printer has more or less the same tension as the 685 mm and the motor belts, but the one on the back off the printer is to loose.
The two 670mm belts are fastened in the same way.
The alignment of the axis is checked and okay.
How can i put more tension to that one belt?
Because of that i have layer shifting.
Kind regards
Before changing the tension of the belts, check the alignment. Most of the layer shifting is due to a slight misalignment of the axis. have a look in the [color=#408040]Wiki[/color].
