Bathroom ventilation
Dear,
I will have bathroom ventilation system at home and I would like to couple, trigger the system when I hit the interruptor of the bathroom. (maybe with delay after that I quit bathroom)
How can I do it? with a relay.
thks for your help
V.
http://www.velleman.eu/distributor/products/view/?id=349988
http://www.velleman.eu/distributor/products/view/?id=376032
Yes,
But I don’t know how I can integrate it in my system? Do I connect both modules?
I have the bus going out from my interruptor
I have 220v on my ventilator
I have 220v for the light (linked to vmb4ry)
thks to help me a little bit for that.
V.
Sorry, but you did not mention you had Velbus.
Of course, you do not need the fan delay modules.
We will look up a document on how to do this and post it on these pages.
Sorry for this omission. So waiting for your advice.
Valery
The relay contact that controls the lamp (Rlamp) must be programmed as ‘toggle’, controlled by the pushbutton.
The relay contact that controls the fan (Rfan) must be programmed as ‘ON’ controlled by Rlamp
The relay contact that controls the fan (Rfan) must also be programmed as ‘activated mode’ controlled by Rlamp
By means of the rotary switches, choose Rfan mode: ‘trigger on release’ and select the desired delay.
