Bad surface?
Hej,
maybe I’m too sophisticated :- )
I think the surface is a little bit too wavy for 0.1mm .
at 0.2mm , it is even worse.
at 0.05mm , it is only marginally better .
I want to print models in scale 1: 160.
image:
https://www.dropbox.com/sc/1af2hw0cp1gwo27/AACUwjm3YjAIgDErnlmPHwF8a
I continue to have the problem of warpings in pla .
maybe you can see it on the image .
the bed is aligned with a gauge (messuhr), the glas is unfotunalety not completely flat (ca 0.07mm)
and the z- axis highnes is adjusted with a feeler gauge (Fühlerlehre).
Printer settings are set by the vertex software.
Does anyone have a solution for me?
and as a last question :
Is it possible to take HIPS or PVA as supporting material ???
Does anyone have experience ?
Unfortunately, I get the support structure not actually removed .
Thanx and best regards.
HIPS works like ABS (I read it here on the forum not my experience since I don’t have HIPS filament).
Scale N (1:160) is really small, you need to calibrate your Vertex really carefully and experiment with the printsettings to achieve an optimal result.
Cheers,
Dylan
I Think You have Z-banding. See here for a sollution
viewtopic.php?f=58&t=13051&p=59203#p59203
