I do not know what the problem is,when I printing,The printer loses orientacion,and moves the table a few cm in axis y,x outside and and continue with printing.
-harness,bandes are tightened
tooth system on the belt also
I need your help,
thanks.
Hi, I have exactly the same problem.
I didn’t build the printer myself, but I have turned the screws up to 547 was roughly as close as I could get, but I still get the problem.
I’m assuming that the printer has to be mains powered when setting this? On usb connected only, it’s a lot lower.
Thing is, I’ve noticed in Repetier, that when this problem occurs, I can move the z axis via the arrow and also the x-axis, but the y-axis will only move backwards (which appears to be the problem, as it is not moving forward for the next layer).
If I HOME the printer, I can then move in both y-axis directions.
The belts are as tight as they should be and move/glide freely when the power is off.
I forgot to add that if the print is under 5cm away from the home position, I get this problem. If it’s just a small piece, fitting into 5cm, from the home position, then it’s fine…
