Autohome
Wen i select autohome the y axis is at end postistion and x axis is at 200%.
Tho at the screen x and y position is at 200%.
Can i reset this so x and y will be at 0% and both at end position after the autohome done its work.
Kind Regards,
Philip
Note: Me and computers dont match!
You mean X200 and Y200.
These values are in mm, the Vertex his home position is centered at X200 Y200 Z0, you can’t change that without changing the position of the end stops.
If you want to move an axis, you can do that in the LCD menu or in Repetier-Host. In the LCD menu you need to select: Control printer -> move axis -> choose a scale -> choose an axe -> turn on the encoder wheel until you have reached your requested position.
Cheers,
Dylan
