AutoCAD drawing of VM8095
is there an AutoCAD drawing of the VM8095 available as .dwg or .dfx file?
Sorry, no.
May we ask why you need this file?
I want to include the VM8095 into a small control system with a programmable controller.
To plan the layout of the mounting plate for the control system in AutoCAD it would be good to have the drawing of the VM8095.
Without it I will only draw a rectangle with the correct dimensions.
PCB dimensions are 160x107mm
On the 4 corners there is a 3.5mm mounting hole
Mounting hole centers are 5mm from the sides of the PCB
