I have a very strange issue. Last week I finished the k8400 with 2 nozzles.
I did several prints this week… worked fine, but suddenly it “broke” with 2 issues :
The auto-home function does not retract the x-axis to utmost right position (y-axis retracts normal), it does not move to the right at all. Instead it moves slightly to the left and stops.
When i use the x-axis controls from the front panel, they work correctly moving left and right.
Now i push the x-axis to the right manually (gently) and start printing.
The printing works fine at first, but after 1 or 2 hours the x-axis starts shifting.
What I have already tried without any change:
- Switching the driver boards
- Tuned the belts
- Oiling the rods
- unplugging/plugging in the x-axis cable on both ends
- Made sure there are no disconnected cables
I have firmware 1.1 for 2 heads (the one that was factory loaded).
I used 1 filament in “single head” setting in repetier, sliced with curaengine.
The strange behaviour of the auto-home worries me. I have not found any topic that describes this.
I wonder if both problems are related?
