I just finish my k8400 yesterday night. It look to work well. I made an accepatble first print. I only have a question about auto home. When I perform this action, the head goes where expected but it’s very noisy. The head move but continue to juddering noisily for 1 or 2 sec. Is it a normal behaviours?
Ok I will check all those things and print some alignement helper.
My understanding is the head should go home smoothly whitout any noise nor juddering. As long as, I have such thing I should rework my alignement. Right?
All is possible but less likely. The axis struggling to reach the home position is more probably a mechanical issue.
To be on the safe side upload the firmware with an Arduino 1.0.6 before testing further.
It was only a mechanical issue. I move a pulley, check lignement, knock the clamps to move it by a fexwthenth of mm, … no more moise when housing.
I made some printing test. For a first try it’s quite good. Incontestablely, it work with a firmware compiled with Andruino 1.6.0 … (setting for Board Mega 2560)
