Are any C# .NET examples of PCGU1000 available for download?
I would like to learn if there are any .NET (in preference C#) examples available, or at least wrapped libraries? Thank you fo ryour prompt answer.
Hi wjw,
What kind of library do you need?
I just created a class with methods translated from the Declare subs/functions in the VB6 demo:
static class PCGU { [DllImport("FGULink.dll")] public static extern void OpenGen(); [DllImport("FGULink.dll")] public static extern void CloseGen(); [DllImport("FGULink.dll")] public static extern void StartGen(); [DllImport("FGULink.dll")] public static extern void StopGen(); [DllImport("FGULink.dll")] public static extern void SetGen(int func, float freq, float ampl, float offset); [DllImport("FGULink.dll")] public static extern void SetSweep( float freq1, float freq2, float ampl, float offset, float time, int form); [DllImport("FGULink.dll")] public static extern void SetLibWave( float freq, float ampl, float offset, int filter, string pointer); [DllImport("FGULink.dll")] public static extern bool GenReady(); [DllImport("FGULink.dll")] public static extern int GenStatus(); [DllImport("FGULink.dll")] public static extern void ShowGen(bool status); [DllImport("FGULink.dll")] public static extern void AttOn(bool att); }
Using the methods is straigtforward, e.g.:
{ PCGU.OpenGen(); //... add code here to wait for loading completion (test GenStatus()) PCGU.SetSweep(20.123F, 450.456F, 3.1F, 1.2F, 12F, 2); MessageBox.Show("StartGen?"); PCGU.StartGen(); MessageBox.Show("Stop?"); PCGU.StopGen(); //... PCGU.CloseGen(); return; }
Hope this can help,
Alain
You will have to create your own .NET wrappers around the dll’s used by PCGU1000. Like iaorana did, through marshaling and P/Invoke. Shouldn’t be too hard
