i have installed all of the needed software and correct version but I am using windows 10 what could be the problem. Still putting Arduino 1.0.6 to Work with the marlin.io it doesn’t start it automatically. fire opening it in Arduino soft en uploading it with the given direction, shunt, power etc. the lights burn, stops then the soft gives me an error about instability. Then trying to go to the menu with wheel on. The side of the LCD display it is hard to get into it now while at the start 1 click was enough. Before I go one with installation is the error displayed in the soft normal or did I do something wrong!
1.0.6 is only needed for the K8200 you can use the latest version of Arduino for the K8400
Can you try again?
