Another feature request
I’ve just acquired the pcsu1000 and find it quite good for my purposes. However, it would be ideal if one could print the Waveform Parameters (the selectable amplitude and timing deatils for the channels) at the same time and preferably on the same page as the waveform itself. I can’t find a way to do this at present.
Thank you brianprobbins for this good idea!
Indeed, it would be nice if the selected waveform parameters can be printed.
This option may be added to the print preview form. Selecting portrait orientation there is a lot of free space to print the waveform parameters below the waveform image.
Also the possibility to print the waveform parameters on the screen can be easily added to the software.
At the moment there is possibility to print a comment text to selected position on the screen by right clicking the screen. The position of the comment can be selected by the next right click on the screen.
Other nice option may be to add the list of the selected waveform parameters to this comment text. You can select proper position on the screen where to print the text.
The comment text and its position are saved and retrieved even if the waveform data is saved using the File menu option “SaveDSO Data”.
I’m sure that these options will be added to the next release of the PCLab2000SE quite soon…
