I’m building the K8200. I’m almost ready. Doing it nice and easy. Very nice quality kit.
Only downside upto now:
- the fan that has a rotor that drops out spontanious. I have two HP minifans (turbines would be a better name, they ask 720 mA per fan. I think I use them both.
- one of the aluminum L-pieces had a casting fault and did not fit, but I milled it and now it fits
- I do not like flatcable. However I give it a try, it is easy to improve if needed.
- the aluminum of the X/Y carriage is very soft, I think to soft. I allready have some ideas to improve that and flatten the heatplate. But that’s for later.
I allready made some small modifications and before I go on everything must be smooth, flat and without freeplay. (allready spend several hours today on measuring/aligning using several micrometers) I’m doing it at this phase because now it is still easy to change and is a good base for the future and still easy to improve small things.
I’m a bit concerd if I read about all the Z ax problems. I do not understand that. There must be huge forces in play there but if I turn the Z ax with my fingers this goes very smooth and even. I’m I just Lucky or are most user-faults ?? (I read about crude things like drilling the stepper connection. Mine did not fit either but I used a “ruimer” and around 15 minutes to make it a very snug fit (do not know the english word, roamer ? )
I placed the printer on a flat surface, adjusted al 4 (modded) legs until all 4 corners and the Z ax frame are within 0,1 mm alike. After that I removed the hotplate and measures the aluminum plate under it. I mounted a micrometer at the profile that holds the extruder and then moved it over the X and Y axis like when it prints. Modded trhe thumbwheels for more easy use…
I now the question on flatness:.
The lowest bed is within 0.03mm at the four corners. But the top bed that also holds the heather itself is not flat due to the very soft aluminum. Just laying something like a screwdriver on the middle gives a sweep to the micrometer. That is realy bad. But maybe I’m over concerned so how flat is flat ? The Heather will become the next problem. I thinik I make an other more rigid one.
It was out of the box within 0.21 mm between middle and edges.
As stated before, the fan is rather useless. I read a fan is importand so I want to use the 2 “turbines” One on each side and later ad 3D printed nozzles to them. Am I correct it is important the do not cool the extruder and neither the hotplate but only cool down the pla that just left the nozle. (I probably make them adjustable because I’m afraid the blow the stuff I’m printing away)
I probably will make a better powersupply but first I will test this one on my dynamic load.
Fred PA4TIM
