Alignment problem. Bent rod or frame not straight?
My Y axis was never really smooth, so I tried realigning everything, and then noticed something odd. Have a look at the video:
goo.gl/photos/wq3eWMwpPygaF4Py7
All pulleys are loose, no matter how I position them as I move the print head over the Y axis, towards the back of the printer, the X belt slacks. i can only explain this if the Y axis rods arent perpendicular? I have no idea how to go about solving this. Suggestions?
Best way to check this I guess is to remove the rods and lay them down on a flat surface and then check if they look by the eye straight.
You told that you did the alignment procedure, but did you also try to knock the clamps with a hammer or so a bit? Like you can see in the procedure on the wiki or on the picture shown below:
This looks like an alignment problem.
Have you seen this procedure?
http://www.k8xxx-3dprinters.crimed.be/w/index.php?title=XY-Carriage_Alignment
Thanks guys, that pretty much solved it.
disclaimer: I did not assemble this printer, so I plead innocence. Or ignorance :slight_smile:
My 8400 has developed the Y grinding noise mostly at full Y and around Home.
Loosened up everything and yes the carriage is stiff round full Y, no hammerering or adjusting seem to help. :frowning:
Help…
Perhaps check if all the bolts that hold together your enclosure are still tight, and there are no spaces between the panels (*), otherwise your rods may be out of alignment.
(*) thats what the manual says. Mine was assembled way too losely, but TBH, Im not entirely sure how hard to tighten all those bolts, there doesnt seem to be a distinctive point where its secure. I’ll also say mine is not entirely without (tiny) open seems. But tightening everything in combination with the instructions in the wiki certainly helped a lot.
A minute after writing this it solved itself! :slight_smile:
With everything loose, I grabbed the side rods seen from the front and pulled with some force outwards, and something that was stuck…well loosened.
Hopefully thi might be of help to somebody.
[quote=“8400”]A minute after writing this it solved itself! :slight_smile:
Hopefully thi might be of help to somebody.[/quote]
Thank you …
JGAURORA 3D printing
jgaurora 3d printer
